Working PWM controller attached to LED strip fixture. Next goal is to test install in a kitchen cabinet with glass doors. If it looks good, I’ll do two more strips for the other shelves and then wire them all into the controller, attached to the extra 12V power supply I installed in the under-cabinet fixture I converted from halogen to LED. The reason for the dimmer is that I just want to add a pleasant glow in the cabinets, not make them very bright.
Michael K Johnson November 06, 2014 21:02
Full brightness is indeed brighter than I want, so the dimmer was a good idea. I’m happy with how it looks, so I guess I need to pick up some more aluminum strip to do the upper two shelves and finish the job.
