CrowdSupply has interesting projects. This one looks convenient!
https://www.crowdsupply.com/amalgam-pdx/quark-tool
Quark Tool
r herrold June 02, 2017 12:43
I’ve had good luck via Amazon with the Gerber EAB Lite Pocket Knife [31-000345] series (there are variants), for under $10
Michael K Johnson June 02, 2017 12:47
Thanks, I wasn’t aware of those. Can you pop the blade out without a screwdriver on them (for the “oops, forgot to remove that from my keychain” in security lines)?
Quark will still be a lot lighter and smaller though. :-)
r herrold June 02, 2017 14:42
the slot on the retaining screw is wide enough that a common house key will loosen the screw for a blade replacement
Isabelle Johnson June 04, 2017 14:48
Or at least an asymptote… :-)
Michael K Johnson June 04, 2017 14:51
That depends on your perspective! ;)
