Deploying Mastodon on CentOS 9 and derivatives
I recently found myself setting up a Mastodon server. Elon Musk threatening to buy Twitter reminded me how fragile it is to live in walled gardens controlled by others. I know something of what it takes to run large-scale applications in the cloud. It’s my job. (Senior Director of Engineering, Platform, at Pendo.) I have some clue what it costs, and I’m not upset at being presented advertisements in Twitter. I even like being recommended content that I didn’t know that I wanted to find!
But I’m not satisfied with what The Algorithm shows me, and I don’t like how my timeline (yes, even after choosing chronological) mutates halfway through my reading a tweet that I wanted to finish but which I’ll never find again. It’s like reading a book when I am dreaming; as soon as I realize I’m reading a book, it fades away and I can’t read it any more. Dreams and Twitter both frustrate me this way.
Many folks don’t remember what it was like when a lot of email was not compatible across systems. Most really don’t understand what a gift it is that you can just ask someone for their “email address” and don’t have to ask them which email service you have to sign up with to talk to them. (The fact that people sometimes ask for your “gmail address” as if there were no other email provider demonstrates that keeping interoperating systems is not the low-energy state.)
I’m not boycotting twitter. I’m still there. But… Remember how as interoperable email started to win, the walled garden email providers eventually had to bridge with it to stay relevant to their uesrs? The more of us move content into the Fediverse, the more pressure there will be for Twitter — and similar networks — to bridge. Right now it’s still niche. But the only way for it to become more mainstream is for more of us to adopt it. (If you don’t remember, just take my word for it.)
And I like having more control over what I see, more options for how to interact. And I really appreciate open standards, like ActivityPub and ActivityStreams.
I am making two contributions to add straw to the camel’s back here: Running Maker Forums Social Mastodon and writing this document about how I deployed it on a modern OS in a way that I believe will make it easy to maintain on an ongoing basis.
Credit
This was heavily based on sleeplessbeastie’s How to take advantage of Docker to install Mastodon but adjusted to work on CentOS 9 derivatives like RHEL, AlmaLinux, and Rocky Linux, and a bit more opinionated, such as recommending a particular backup solution.
Installation
I started from AlmaLinux 9, and the configuration I used during installation was:
- Set hostname to the fully-qualified domain name
- Select “Custom Storage Configuration”, then “Create default configuration”
- Decreased swap to 2GB — if you are swapping much, this system won’t work well anyway
- At least 10GB root (my 15GB appears to be excessive)
- At least 15GB /var/lib/docker (my 25GB appears to be excessive)
- The rest of the space for /opt/mastodon
- Software Selection
- Server (instead of the default server with GUI) on the left, then on the right add
- Guest Agents
- Debugging Tools
- Mail Server
Preparation
If you need to temporarily allow password login by SSH during installation, the
first task after installation is to set up SSH keys and then disable password login.
After confirming that key-based login works, modify /etc/ssh/sshd_config
to say
PasswordAuthentication no
and then systemctl restart sshd
It should be possible to use podman to manage this, and I’d be delighted to add to this document a pointer to similar instructions on doing that. I chose to use Docker.
I used the CentOS Docker package
instructions
converting from yum
usage to dnf
usage:
# dnf config-manager --add-repo https://download.docker.com/linux/centos/docker-ce.repo
# dnf install --allowerasing docker-ce docker-ce-cli containerd.io docker-compose-plugin
(I needed to include --alloweraseing
because of a conflict with podman
and buildah
that are
already installed; they need to be erased to install docker.)
# systemctl enable docker
# systemctl start docker
Some of the containers need to reach out to the internet to do their jobs, and
the server needs to respond to http
and https
requests.
# firewall-cmd --add-service http --add-service https --zone public
# firewall-cmd --zone=public --add-masquerade
# firewall-cmd --runtime-to-permanent
Elasticsearch is needed for search, and it needs to increase this setting:
# echo "vm.max_map_count=262144" > /etc/sysctl.d/90-max_map_count.conf
# sysctl --load /etc/sysctl.d/90-max_map_count.conf
Use memory more efficiently:
# echo 'vm.overcommit_memory=1' > /etc/sysctl.d/90-vm_overcommit_memory.conf
# sysctl --load /etc/sysctl.d/90-vm_overcommit_memory.conf
SELinux needs one change for this to work.
# setsebool -P httpd_can_network_connect 1
If you do not plan to use cockpit, you can further reduce footprint. I chose:
# dnf erase $(rpm -qa | grep cockpit) --exclude=jq,parted,gdisk
Install nginx on the host
# dnf install nginx
Application
Now you’re finally ready to start installing Mastodon itself. Make room for Mastadon to live in:
# mkdir -p /opt/mastodon/database/{postgresql,pgbackups,redis,elasticsearch}
# mkdir -p /opt/mastodon/web/{public,system}
# mkdir -p /opt/mastodon/branding
# chown 991:991 /opt/mastodon/web/{public,system}
# chown 1000 /opt/mastodon/database/elasticsearch
# chown 70:70 /opt/mastodon/database/pgbackups
# cd /opt/mastodon
# touch application.env database.env
Create /opt/mastodon/docker-compose.yml
version: '3'
services:
postgresql:
image: postgres:14-alpine
env_file: database.env
restart: always
shm_size: 512mb
healthcheck:
test: ['CMD', 'pg_isready', '-U', 'postgres']
volumes:
- postgresql:/var/lib/postgresql/data
- pgbackups:/backups
networks:
- internal_network
# pgbouncer:
# image: edoburu/pgbouncer:1.12.0
# env_file: database.env
# depends_on:
# - postgresql
# healthcheck:
# test: ['CMD', 'pg_isready', '-h', 'localhost']
# networks:
# - internal_network
redis:
image: redis:7-alpine
restart: always
healthcheck:
test: ['CMD', 'redis-cli', 'ping']
volumes:
- redis:/data
networks:
- internal_network
redis-volatile:
restart: always
healthcheck:
networks:
- internal_network
elasticsearch:
image: elasticsearch:7.17.4
restart: always
environment:
- cluster.name=elasticsearch-mastodon
- discovery.type=single-node
- bootstrap.memory_lock=true
- xpack.security.enabled=true
- ingest.geoip.downloader.enabled=false
ulimits:
memlock:
soft: -1
hard: -1
healthcheck:
test: ["CMD-SHELL", "nc -z elasticsearch 9200"]
volumes:
- elasticsearch:/usr/share/elasticsearch/data
networks:
- internal_network
website:
image: tootsuite/mastodon:v3.5.3
env_file:
- application.env
- database.env
command: bash -c "bundle exec rails s -p 3000"
restart: always
depends_on:
- postgresql
# - pgbouncer
- redis
- redis-volatile
- elasticsearch
ports:
- '127.0.0.1:3000:3000'
networks:
- internal_network
- external_network
healthcheck:
test: ['CMD-SHELL', 'wget -q --spider --proxy=off localhost:3000/health || exit 1']
volumes:
- uploads:/mastodon/public/system
shell:
env_file:
- application.env
- database.env
command: /bin/bash
restart: "no"
networks:
- internal_network
- external_network
volumes:
- static:/static
streaming:
env_file:
- application.env
- database.env
command: node ./streaming
restart: always
depends_on:
- postgresql
# - pgbouncer
- redis
- redis-volatile
- elasticsearch
ports:
- '127.0.0.1:4000:4000'
networks:
- internal_network
- external_network
healthcheck:
test: ['CMD-SHELL', 'wget -q --spider --proxy=off localhost:4000/api/v1/streaming/health || exit 1']
sidekiq:
env_file:
- application.env
- database.env
command: bundle exec sidekiq
restart: always
depends_on:
- postgresql
# - pgbouncer
- redis
- redis-volatile
- website
networks:
- internal_network
- external_network
healthcheck:
test: ['CMD-SHELL', "ps aux | grep '[s]idekiq\ 6' || false"]
volumes:
networks:
external_network:
internal_network:
# internal: true
volumes:
postgresql:
driver_opts:
type: none
device: /opt/mastodon/database/postgresql
o: bind
pgbackups:
driver_opts:
type: none
device: /opt/mastodon/database/pgbackups
o: bind
redis:
driver_opts:
type: none
device: /opt/mastodon/database/redis
o: bind
elasticsearch:
driver_opts:
type: none
device: /opt/mastodon/database/elasticsearch
o: bind
uploads:
driver_opts:
type: none
device: /opt/mastodon/web/system
o: bind
static:
driver_opts:
type: none
device: /opt/mastodon/web/public
o: bind
(Note: I have not tested the pgbouncer configuration; that is copied from sleeplessbesatie’s guide, and I have left it commented out in case I later need to add pgbouncer to my configuration.)
You can choose whether to use major versions and auto-upgrade minor versions with docker compose pull
or manually change minor versions, for redis and postgresql.
You will want to lock mastodon to a specific version, follow updates
(ATOM), and
observe update procedures called out in the release notes when upgrading Mastodon.
There is no major version tag for Elasticsearch on docker, so regularly check
Elastic Docker Hub especially for security updates
to address Java security flaws as they are discovered.
Note: you cannot set the internal_network
as an internal network and use firewalld.
The default docker-compose.yml that comes with Mastodon sets:
networks:
external_network:
internal_network:
internal: true
That internal: true
doesn’t work with firewalld,
which is why it is commented out in the docker-compose.yml here. If this is ever fixed, you may
be able to re-add that additional restriction.
Now download all the images required to compose your system.
# docker compose pull
Secrets
It’s time to fill in application.env and database.env.
Here’s a template application.env file:
# environment
RAILS_ENV=production
NODE_ENV=production
# domain
LOCAL_DOMAIN=your.server.fqdn
# redirect to the first profile
SINGLE_USER_MODE=false
# do not serve static files
RAILS_SERVE_STATIC_FILES=false
# concurrency
WEB_CONCURRENCY=2
MAX_THREADS=5
# pgbouncer
#PREPARED_STATEMENTS=false
# locale
DEFAULT_LOCALE=en
# email, not used
SMTP_SERVER=mailserver.invalid
SMTP_PORT=587
SMTP_LOGIN=mastodon
SMTP_PASSWORD=ifYouNeedId
SMTP_FROM_ADDRESS=notifications-noreply@your.server.fqdn
# secrets
SECRET_KEY_BASE=add
OTP_SECRET=add
# Changing VAPID keys will break push notifications
VAPID_PRIVATE_KEY=add
VAPID_PUBLIC_KEY=add
To generate values for SECRET_KEY_BASE
and OTP_SECRET
# docker compose run --rm shell bundle exec rake secret
To generate values for VAPID_PRIVATE_KEY
and VAPID_PUBLIC_KEY
# docker compose run --rmshell bundle exec rake mastodon:webpush:generate_vapid_key
Here’s a template database.env file:
# postgresql configuration
POSTGRES_USER=mastodon
POSTGRES_DB=mastodon
POSTGRES_PASSWORD=generate1
PGPASSWORD=generate1
PGPORT=5432
PGHOST=postgresql
PGUSER=mastodon
# pgbouncer configuration
#POOL_MODE=transaction
#ADMIN_USERS=postgres,mastodon
#DATABASE_URL="postgres://mastodon:generate1@postgresql:5432/mastodon"
# elasticsearch
ES_JAVA_OPTS=-Xms512m -Xmx512m
ELASTIC_PASSWORD=generate2
# mastodon database configuration
#DB_HOST=pgbouncer
DB_HOST=postgresql
DB_USER=mastodon
DB_NAME=mastodon
DB_PASS=generate1
DB_PORT=5432
REDIS_HOST=redis
REDIS_PORT=6379
CACHE_REDIS_HOST=redis-volatile
CACHE_REDIS_PORT=6379
ES_ENABLED=true
ES_HOST=elasticsearch
ES_PORT=9200
ES_USER=elastic
ES_PASS=generate2
To generate keys for the generate1
and generate2
values, use
# openssl rand -base64 15
Bring up
With the environment files filled with secrets and keys, initialize those services. First get the static files ready to be served directly by nginx on the host:
# docker compose run --rm shell bash -c "cp -r /opt/mastodon/public/* /static/"
The Mastodon developers are opposed to making additional branding more accessible through the web interface, so you should expect to have to continue to maintain this. If you want to modify any of the static files, such as favicon.ico, put copies of them in /opt/mastodon/branding/ permanently, and then run:
# cp -f /opt/mastodon/branding/* /opt/mastodon/web/public/
Then bring up the data layer.
# docker compose up -d postgresql redis redis-volatile
# watch docker compose ps
Wait for running (healthy)
, then Control-C
and initialize the database.
# docker compose run --rm shell bundle exec rake db:setup
Note that later, after each mastodon update, you will need to run all database migrations, and update your copies of static files and re-add any branding overrides:
# docker compose run --rm shell bundle exec rake db:migrate
Handle HTTPS
Install certbot
# dnf config-manager --set-enabled crb
# dnf install epel-release
# dnf install certbot
# systemctl enable --now certbot-renew.timer
Get a key. You’ll have to answer a bunch of questions. Make sure you include the FQDN of the server!
# certbot --nginx
Now create /etc/nginx/conf.d/mastodon.conf
and change
mastodon.example.com
everywhere to the fully-qualified domain name for your server:
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
upstream backend {
server 127.0.0.1:3000 fail_timeout=0;
upstream streaming {
server 127.0.0.1:4000 fail_timeout=0;
proxy_cache_path /var/cache/nginx levels=1:2 keys_zone=CACHE:10m inactive=7d max_size=1g;
server {
listen 80;
server_name mastodon.example.com;
location / { return 301 https://$host$request_uri; }
server {
listen 443 ssl http2;
ssl_protocols TLSv1.2 TLSv1.3;
ssl_ciphers HIGH:!MEDIUM:!LOW:!aNULL:!NULL:!SHA;
ssl_prefer_server_ciphers on;
ssl_session_cache shared:SSL:10m;
ssl_session_tickets off;
ssl_certificate /etc/letsencrypt/live/mastodon.example.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/mastodon.example.com/privkey.pem;
keepalive_timeout 70;
sendfile on;
client_max_body_size 80m;
root /opt/mastodon/web/public;
gzip on;
gzip_disable "msie6";
gzip_vary on;
gzip_proxied any;
gzip_comp_level 6;
gzip_buffers 16 8k;
gzip_http_version 1.1;
gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript image/svg+xml image/x-icon;
add_header Strict-Transport-Security "max-age=31536000" always;
location / {
try_files $uri @proxy;
location ~ ^/(system/accounts/avatars|system/media_attachments/files) {
add_header Cache-Control "public, max-age=31536000, immutable";
root /opt/mastodon/;
location ~ ^/(emoji|packs) {
location /sw.js {
add_header Cache-Control "public, max-age=0";
location @proxy {
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header Proxy "";
proxy_pass_header Server;
proxy_pass http://backend;
proxy_buffering on;
proxy_redirect off;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
proxy_cache CACHE;
proxy_cache_valid 200 7d;
proxy_cache_valid 410 24h;
proxy_cache_use_stale error timeout updating http_500 http_502 http_503 http_504;
add_header X-Cached $upstream_cache_status;
tcp_nodelay on;
location /api/v1/streaming {
proxy_pass http://streaming;
proxy_buffering off;
proxy_redirect off;
tcp_nodelay on;
error_page 500 501 502 503 504 /500.html;
systemctl enable --now nginx.service
Tootctl
The tootctl CLI tool is essential for administering Mastodon. Make it accessible via the Mastodon shell docker image with a simple shell script.
Contents of /root/bin/tootctl
#!/bin/bash
docker compose -f /opt/mastodon/docker-compose.yml run --rm shell tootctl "$@"
Then:
# chmod +x /root/bin/tootctl
Start mastodon
More systemd unit files!
Contents of /etc/systemd/system/mastodon.service
[Unit]
Description=Mastodon service
After=docker.service
[Service]
Type=oneshot
RemainAfterExit=yes
WorkingDirectory=/opt/mastodon
ExecStart=/usr/bin/docker compose -f /opt/mastodon/docker-compose.yml up -d
ExecStop=/usr/bin/docker compose -f /opt/mastodon/docker-compose.yml down
[Install]
WantedBy=multi-user.target
Then run
# systemctl daemon-reload
# systemctl enable --now mastodon.service
# watch docker compose -f /opt/mastodon/docker-compose.yml ps
before the next step. This will probably take 30 seconds to a minute.
Create admin user
# tootctl accounts create $admin-user --email admin-user@mail.invalid --confirmed --role admin
Create new secure password, then disable registration during setup.
# tootctl settings registrations close
If you later want to open registrations, go ahead whenever you want to.
# tootctl settings registrations open
Cleanup
Contents of /etc/systemd/system/mastodon-media-remove.service
[Unit]
Description=Mastodon - media remove service
Wants=mastodon-media-remove.timer
[Service]
Type=oneshot
StandardError=null
StandardOutput=null
ExecStart=/usr/bin/docker compose -f /opt/mastodon/docker-compose.yml run --rm shell tootctl media remove
[Install]
Contents of /etc/systemd/system/mastodon-media-remove.timer
[Unit]
Description=Schedule a media remove every week
[Timer]
Persistent=true
OnCalendar=Sat *-*-* 00:00:00
Unit=mastodon-media-remove.service
[Install]
WantedBy=timers.target
Contents of /etc/systemd/system/mastodon-preview_cards-remove.service
[Unit]
Description=Mastodon - preview cards remove service
Wants=mastodon-preview_cards-remove.timer
[Service]
Type=oneshot
StandardError=null
StandardOutput=null
ExecStart=/usr/bin/docker compose -f /opt/mastodon/docker-compose.yml run --rm shell tootctl preview_cards remove
[Install]
Contents of /etc/systemd/system/mastodon-preview_cards-remove.timer
[Unit]
Description=Schedule a preview cards remove every week
[Timer]
Persistent=true
Unit=mastodon-preview_cards-remove.service
[Install]
Now start them up
# systemctl enable --now mastodon-preview_cards-remove.timer
# systemctl enable --now mastodon-media-remove.timer
Backups
I chose to use restic. Use what you want, but here’s an easy-to-apply pattern using restic.
Contents of /opt/mastodon/backup-files
/etc/nginx
/etc/letsencrypt
/etc/systemd/system
/root
/opt/mastodon/*.env
/opt/mastodon/mastodon-backup
/opt/certbot
Now run:
# dnf install restic
# restic -r s3:https://$SERVER:$PORT/mybucket init
# restic -r s3:https://$SERVER:$PORT/mybucket backup $(cat /opt/mastodon/backup-files) --exclude /opt/mastodon/database/postgresql
Contents of mastodon-backup.timer
[Unit]
Description=Schedule a mastodon backup every hour
[Timer]
Persistent=true
OnCalendar=*:00:00
Unit=mastodon-backup.service
[Install]
Contents of mastodon-backup.service
[Unit]
Description=Mastodon - backup service
# Without this, they can run at the same time and race to docker compose,
# double-creating networks and failing due to ambiguous network definition
# requiring `docker network prune` and restarting
After=mastodon.service
[Service]
Type=oneshot
StandardError=null
StandardOutput=null
ExecStart=/bin/bash /opt/mastodon/mastodon-backup
[Install]
Contents of /opt/mastodon/mastodon-backup
will need some pieces filled in.
Do keep in mind that you also need to store the restic password somewhere
safe; if it’s only on this system and no where else, your backup is no better
than a pile of random data. It’s important to start this after mastodon.service
because otherwise mastodon and mastodon-backup will race to create the docker
networks, will both succeed in creating the networks,and then be very confused
by the duplicate networks. If this ever happens to you, docker network prune
will remove duplicate networks and you can start over.
#!/bin/bash
set -e
AWS_ACCESS_KEY_ID=
AWS_SECRET_ACCESS_KEY=
SERVER=
PORT=
RESTIC_PASSWORD_FILE=/root/restic-pasword
docker compose -f /opt/mastodon/docker-compose.yml run --rm postgresql sh -c "pg_dump -Fp mastodon | gzip > /backups/dump.sql.gz"
Now start them up
# chmod +x /opt/mastodon/mastodon-backup
# systemctl enable --now mastodon-backup.service
# systemctl enable --now mastodon-backup.timer
Confirm that hourly backups are happening and accessible using
# restic -r s3:https://$SERVER:$PORT/mybucket snapshots
# restic -r s3:https://$SERVER:$PORT/mybucket mount /mnt
Search
Search will (as of this writing) fail to deploy until at least one local toot has been made. After the first toot on your server, initialize search:
# tootctl search deploy
Questions?
I’ll try to improve this post to address your questions if I know the answers. Feel free to reach out by comments either on Mastodon or (ironically) on Twitter.
