Don’t let me giving away the punchline keep you from reading the whole thing:
If you have an implicit schema — meaning, if there are things you are expecting in that JSON — then MongoDB is the wrong choice. I suggest taking a look at PostgreSQL’s hstore (now apparently faster than MongoDB anyway), and learning how to make schema changes. They really aren’t that hard, even in large tables.
Sarah Mei » Why You Should Never Use MongoDB
Eugene Crosser November 21, 2013 01:24
Such an amusing and well written (and longish) post.
All to explain a problem that is glaringly obvious from the start…
Michael K Johnson November 21, 2013 06:07
If it were glaringly obvious to most people, the article wouldn’t have been written in the first place. ☺
Perhaps the problem is that “MongoDB” has the letters “DB” in immediate proximity and capitalized, misleading people into thinking that it is intended to be a database. Frankly, when I see “DB” in a name, I tend to assume that was at least the intent until I understand to the contrary.
David Megginson November 21, 2013 10:23
It’s basically the beginning of the end of the #NoSQL movement as such — it needs to start defining itself by what it is instead of what it isn’t.
