“I entered the pattern and then was in key positon and instead of applying carb heat in the little Cessna 150, I pulled the throttle and cut the power! Whoops!”
That brings back old memories. I think it was my first solo when I did the same thing, but with no instructor to catch it. Training kicked in, though—immediately start lining up for a no-power approach, then do the left-to-right scan from switches to throttle quadrant, see the problem, apply power, add carb heat, clear airspace above the high-wing plane, and return to a normal pattern. No more than 5 seconds from beginning to end, and a great lesson in the value of drilling.
Sometimes I miss flying.
https://airfactsjournal.com/2018/07/fitting-in-flying-around-a-busy-life-and-learning-a-lesson/
Fitting in flying around a busy life - and learning a lesson | Air Facts Journal
